The on going cooling problem
1.8K views 12 replies 6 participants last post by  triger0
#1 ·
Ok I put in a new Thermostat,hard wired the fan where it stay's on high when key is on,AND new radiator cap:mad!!!!!!!!! my car still over heats what eals could it be???? I neeed HELP :help SOON. I dont know what to do..
#3 ·
OK so since no one would help me I have blead the system and the cooling started working super good. But them I drove it for 50 miles and left it running for 20 min. Water started coming out of the radiator cap. What could be wrong now??? Please some one help me I am about the end of my nerve:emo
#7 ·
Well good news is I reblead the lines and it's working so far. But I think I will have a overflow but any of the 54 other peep on here who are looking at this will this be normal just let it overflow without refill our what? For those of you just looking why be on this thred if just look. Give some in put. As a saying that I saw on a nonther member said "United we stand alone we fall" I for one 2nd that.......
#11 ·
Dude, dis problem is one I don't pray my enemies shld have( or y not? enemies right?).
What i usually do after bleeding is to use a hose & suck out excess water till it gets to water mark.
Also check the water pump, impeller blades cld have corroded.
Check dat fans blow in right direcn.
If fan isn't on a relay, now wld be a good time to install one.
How "old" is dis engine anyway? (mileage)
I sincerely hope the gasket, worse top cylinder is ok.
Hola back.
