Ok I put in a new Thermostat,hard wired the fan where it stay's on high when key is on,AND new radiator cap!!!!!!!!! my car still over heats what eals could it be???? I neeed HELP SOON. I dont know what to do..
Also the heater does not heat at all nothen but cold air????
OK so since no one would help me I have blead the system and the cooling started working super good. But them I drove it for 50 miles and left it running for 20 min. Water started coming out of the radiator cap. What could be wrong now??? Please some one help me I am about the end of my nerve
I'm a TOTAL noob man but if i were you since no ones answerin.. try lookin or postin on bimmerforums.com? i dont even have an account there but i hear its a pretty big forum and you might be able to find help there?
sorry i couldnt be more help,
Pete
Hay thanks just put it on there hope full someone can help........
Well good news is I reblead the lines and it's working so far. But I think I will have a overflow but any of the 54 other peep on here who are looking at this will this be normal just let it overflow without refill our what? For those of you just looking why be on this thred if just look. Give some in put. As a saying that I saw on a nonther member said "United we stand alone we fall" I for one 2nd that.......
Uh, I also am a n00b, but I hate to see you left hanging, so here's my two cents: I think your water pump (coolant pump) is bad. Big job, but that's my guess... Good luck, bro.
DUDE i had the same prob...do ur fans turn on??? maybe a relay is bad.....or it could be not enough coolant nd it is getting clogged somewhere.......hmmm heater core maybe...dude...i had mine just fixed..it runs like a champ....good luck wit the fix...
Dude, dis problem is one I don't pray my enemies shld have( or y not? enemies right?).
What i usually do after bleeding is to use a hose & suck out excess water till it gets to water mark.
Also check the water pump, impeller blades cld have corroded.
Check dat fans blow in right direcn.
If fan isn't on a relay, now wld be a good time to install one.
How "old" is dis engine anyway? (mileage)
I sincerely hope the gasket, worse top cylinder is ok.
Hola back.
well found out the hard way what was wrong with my car it was a blown head gasket. But to all of those who helped me out thank you.
Hola back.
well as you see it was the head gasket!!!! its going to cost me 650 to fix. this is the best car I have owned to date. I have had it 1 month and it's cost me 1,600 so far. So I dont know what to do anymore
