Can someone tell me how to access the windscreen wash jets on my 1998 728? I think the drivers side tubing has come off as there is no spray on that side and very weak spray on the passenger side. Hopefully someone can tell me how to get to the tube so I can put it back on and see out of my windscreen again.
thank
Mick.
just take out the hood liner. then you will have access to them
First get a toothpick, or unbend a paper click, and poke at the washer jets. They may just be clogged.
Otherwise, pry away the padding under the hood where the jets are located, you should be able to trace the tubes from there, and possibly see if they need replacing.
