window switches - 92 525i
2685 Views 3 Replies 3 Participants Last post by  posmaxx
G
I've got a 92 525i, and I think the window switch in the center console needs to be replaced. Does the switch cluster just pop out, or is there more to it?
Get a shop manual for your car, it will have detailed instructions with pictures.
it should pop out. i dont know what u mean by the cluster tho ;)
Just use a butter knife and pry the switch from console carefully at left and right side. It should pop out easily. It usually just need good cleaning for it to be working properly. I used electronic cleaner (you can get it from Radioshack) and works like a charm.
Cheers!
See less See more
