I am in need of winter wheels and tires BADLY, I know a guy that is selling a set of OEM 99 323i 15" wheels, and he says they will fit all E36 318's and 325's. I wanted to check with you guys. Are they going to fit, is the bolt pattern the same and the brake clearance good?? thanks in advance guys.
aaron
Yes these whels will fit the same as your stok wheels.
ok, I'm a schmuck.. I just went to discounttiredirect.com and checked out the bolt pattern and offset of the wheels between the 2 cars... I should've done that before i posted here... duhh, i'm retarded or somethin...
