i got this kinda like ticking sound comming from my back left wheel and i cant figure it out and also i noticed all my break pads are touching the rotors when the the breaks are applied can anybody help me. Thanks guys!
First off check your tyre for stones in the tread or a screw/nail, easier if the wheel is removed, as for your pads touching the rotor/discs when you apply the brakes...thats what they are suppose to do.
sorry typo when the breaks are NOT applied and thank you i will check today but it sounds more like a suspension problem.
After some driving, you could feel the tires, temperature of each pair of front or rear should be uniform. if not, a brake calliper could be stuck and not 'returning' freely. also check for uniform pad wear. Ordinarily looking at the brakes, it appears to be touching the discs.
