i got underneath my car today to try to find the oil drain plug on my 328i. i see this huge cover covering the first third of the front of the bottom of the engine bay, and approximately near the center of this cover, i see a hole and through this hole appears to be a 17mm bolt head of some sort. is this the drain plug that i am looking for?? if not, then where the heck is it??
It's on the passenger's side of the oil pan. Do you know what the oil pan looks like?
not really. it's hard to tell where anything is with that cover in the way. do i have to remove this cover to see the oil pan and plug??
Oh damn, I didn't realize this was e46 and not e36. Sorry bub, i gots an e36 so I'm 100% completely useless to you. MAYBE the e46 mod, or someone else, can answer your question for you ....
i belive the e46 oil pan is not covered, check again. youll see the plug
phillips head screw driver will get that cover out of your way. There's like 6 or 8 (forget exactly) silver phillips head screws holding that cover on. They are 1/2 scres so just twist and they spring out. This will gain you access to the oil pan and on the side at the bottom is a 17mm drain plug. DON'T FORGET THE COPPER WASHER ON THE PLUG
depending on the year, there maybe an access "flap" which is secured by one quick release fastenener. But, that usually ends up with a mess anyway; easier to just remove it anyway.
