1 - 9 of 9 Posts
i just purchased a chromed set of bbs wheels for my wife's 2000 740iL. one wheel is missing the emblem, how do i know if i need the 64.5 or the 65 mm emblem. can someone convert that into inches for me..
If these two measurements are from different sites, it could be the same part and one site is just rounding up.
On the other hand: If they are two different parts, there is probably a reason for it.
42, The meaning of life
If you already have one that you can measure, measure it and then you'll know. I am guessing that as North said, they could be the same size, just someone being overly accurate. If anything I'd go with the smaller option because it will fit into a larger hole, but not the other way round.
Good luck.
Discussion Starter · #9 ·
Good luck.
thanks brettsky, i just got the wheels and measured the opening. 2.75" which turns out to be 70mm after all... got some on order.
1 - 9 of 9 Posts
