ABS(Anti-Braking System) will play a crucial role in enhancing the safety as the system ensures that even under hard braking, none of the wheels get locked. This gives the driver better control over the vehicle as s/he can steer the vehicle around an object and avoid impact. ABS also reduces braking distance significantly, both in dry and wet conditions.
So after replacing ABS components, we need to initialize related ECU info.
Note:
Keep ignition ON and make sure that ECU battery is full. The tool I use for initialization is Topdon Artipad.
Steps:
Choose the correct car models and year.
Choose the correct system: ABS-service function-Initialization
Choose the correct option: “After replacing ECU or related components”
And the display prompt specific operation: keep car stay still and horizontal. Keep wheels aligned, release brake paddle.
Then the ESC initialization is done.
If the tool detects G sensor, it will re-calibrate. And this is the reason why we need car to stay horizontal.
And the tool will detect if ESC system was installed, if yes, need to turn ignition OFF and ON again.
From here are a little bit complicated steps, start the engine first and drive at 3-15mph, turn around at least 90 degrees. ESP indicator will flash till the process finishes.
Step on brake paddle and turn steering wheel to the very left, and then very right, and very left again, then to the center.
Drive at 3-15mph, turn around at least 90 degrees and drive for another 50 inches, stops, keep driving to see if screen prompt test succeed.
Now need to clear steering info in ECU, stop the engine but leave ignition on and top on TES on screen.
Finally, the ABS initialization is done, comparing to other maintenance, this procedure is rather complicated, so maybe ask a technician to do this for you is also a good option, but it’s always good to know what would a technician do to your car.
Hope this article is helpful.
tn govt jobs
Government Jobs are in demand in India for longer profession options and stability. It offers a superb threat to serve the nation without delay. It is no secret that most process seekers choice to get Sarkari Naukri (Government Job). But getting a great authorities task everywhere inside the global and specifically in India may be very tough. It calls for endurance, a variety of effort, preparedness, alertness, smartness, and success also to obtain the Official website target of getting a terrific authorities job.
free job alert hp
Governments in India, whether or not Central or State, commonly, ask for applications from suitable applicants both via offline methods or through on line strategies. The offline approach is getting used much less and much less in recent times and normally, all government task utility methods are shifting to finish online structures.
Babies
Guide’s In Child’s Growth Journey & Beyond. Many things have to be kept in mind, like baby names, motherhood, breastfeeding, newborn’s health issues, stressful days, and other parenting tips. We are here to make your journey a bit easy, if not smooth. We know that you will be the only one to suffer all the frustrations and agony. However, we have stretched our helping hand to make sure that your child’s growth is persistent and never hindered.
