1 - 10 of 10 Posts
hi
need help just purchased a conv330ci late 2003 with tv and nav and would like some info on how to fix the tv problem up...
what is the problem with the tv?
Originally posted by billyabbs@Sep 25 2003, 12:32 PM
hi
Not to be harsh, but if we knew what the problem was, we just may be able to help you.
"I'm having a problem with a component in my car. Any gueses as to how I can fix it?" -- :banghead :confused
Oh, and :welcome
I'll help you out bro. You must be talking about tv shutting off the moment you put the gear in drive. www.nav-tv.com can fix it for you for several hundred bucks. I hope I got the address right
i got a question to relate to this. my friend has a pioneer tv/nav dvd system. is it possible to play movies/watch tv while drivin with one of those? and is it possible to play dvds in the dvd nav system?
yes, the link www.navtv.com has products that can fix this for you.
e36_332i, i'm not sure, but i think the aftermarket products should be able to play while in motion, again, i'm not sure. also, i believe you will need to have a separate DVD player in order to play movies. the DVD's will not work in the DVD nav system.
There is an interlock because it is illegal to drive with a television playing in the front seat of a vehicle.
That said, our local installer deactivated the "interlock" for about $100 after having us sign a waiver (I guess that they don't want a lawsuit regarding an accident caused while "distracted" watching TV while driving!).
It is possible, but the reason is that it's the law, not a problem with aftermarket manufacturers missing a good feature.
To watch the movie/nav while driving, you need to find the wire that goes from the back of the radio to the park switch in the shifter, then ground it out. I had a 2000 Stratus, that I put a Kenwood indash dvd player into. It said to put one wire to the side to the park witch that was ground only in park. Hope this helps.
1 - 10 of 10 Posts
