Volvo V50
Autoindex
Volvo has issued the following press release:
Strong emphasis on “sport” – as well as “wagon”.
The Volvo V50 is the perfect car for people who want a youthful, cool look. And it comes with a valuable “bonus” – the practical details and extra loading space.
The new Volvo V50 is a genuine premium car, with properties that appeal directly to young families on the move. They have one or two children. They are active people looking for a premium car.
Our target is to sell 74,000 cars a year with the first deliveries early in 2004.
Like the all-new Volvo S40, the Volvo V50 will be built at the Volvo Cars plant in Ghent, Belgium.
When fully extended, the Ghent Plant will be the company’s largest production unit with an annual capacity of 270,000 cars.
The ultimate design icon of the new Volvo V50
The most distinctive feature inside the new Volvo V50 is the unique, super-slim, free-floating centre stack that elegantly links the tunnel console with the instrument panel.
The controls in the new centre stack have an ergonomic, functional design. Most of them are used for several functions, in a logical and convenient way. The top half of the control panel is used to operate the audio system, integrated phone and navigation system, while the lower half controls the climate system.
Behind the centre stack, there is a practical storage compartment for personal items, easily accessible from both sides.
A modern sportswagon
The rear of the Volvo V50 has a softer, more sports-oriented design than the very typical estate model, the V70. The combination of rounded roof lines and extremely abrupt tail is designed to create a modern, flair-filled impression.
The Volvo V50 is 46 mm longer than the new S40.
New, patented frontal structure with several crumple zones
The new Volvo V50 has very high safety levels – both protective and preventive. Volvo’s aim was to attain the same high safety level as in the Volvo S80.
The frontal body structure of the Volvo V50 is divided into several zones, each with a different task in the deformation process. The outer zones are responsible for most of the deformation. The closer the collision forces get to the passenger compartment, the less the materials used deform.
Compact engines contribute to crash safety
Efficient packaging has enabled the five-cylinder engines in the new Volvo V50 to be made 200 mm slimmer. As the engines are installed transversely, the reduced width creates greater space between engine and passenger compartment.
In a collision, the engine can be pushed no less than 150 mm rearwards before the crankshaft is stopped by the cross-member near the bulkhead.
The new Volvo V50 also shares the same type of interior safety system as that found on the larger Volvo models, including WHIPS (Whiplash Protection System), SIPS (Side Impact Protection System) with side-impact airbags and inflatable curtains.
The all-new Volvo V50 is 54 mm wider than its predecessor, the V40. This creates added space for deformation in a side impact.
Protection for other road users
The design of the new Volvo V50 has a front characterised by clean, smooth surfaces and rounded corners. The curves and panels are shaped to help reduce the risk of injury to pedestrians and cyclists in the event of an accident. Furthermore, the front has an energy-absorbing structure ahead of the bumper to help reduce the risk of leg injuries.
The bonnet and front wings are designed to absorb collision energy. This helps reduce the risk of head injuries. In addition, the compact new petrol engines leave a generous 70 mm of free space between the cylinder head and bonnet.
Stable driving properties
The body of the new Volvo V50 is 34 per cent stiffer than that of its predecessor, the V40, thanks to advanced body design.
The suspension is independent all round, with spring struts at the front and a multilink system at the rear. The rear suspension provides a certain degree of passive steering to counteract any tendency to skid.
Depending on the market, the new Volvo V50 comes as standard – or can be specified with:
• STC (Stability and Traction Control) anti-spin system
• DSTC (Dynamic Stability and Traction Control), which corrects the progress and poise of the car if it displays any tendency to skid
The new Volvo V50 has ABS brakes – with electronic brake-force distribution to the rear wheels and automatic panic-braking assistance – EBA (Emergency Brake Assistance). The front wheels feature ventilated discs. The disc size is adapted to engine power (diameter up to 16.5").
Unique Intelligent Driver Information System (IDIS)
The new Volvo V50 is equipped with IDIS – the Intelligent Driver Information System.
IDIS is a car industry innovation, first shown in the all-new Volvo S40. It is influenced by fighter aircraft technology. The system helps the driver to avoid being distracted while driving.
In demanding situations, such as overtaking or braking, signals from the integrated GSM telephone and certain peripheral information are delayed until the situation is calmer.
IDIS is standard in all versions of the new Volvo V50, irrespective of whether or not the car is fitted with an integrated phone.
Keyless Drive – key-less locking system
The Volvo V50 can be specified with a key-less locking/unlocking system. This makes it possible to open or lock the car and turn on the engine without using a key. In order to do this, the driver needs to carry what is known as a PAD (Passive Authorisation Device).
Powerful engines for silky-smooth progress
The new Volvo V50 has transverse, five-cylinder, in-line engines. Most of the external engine components have been designed and packaged so that the installation takes exceptionally little space.
The result is an engine that is 200 mm slimmer and 25 mm shorter than that found in the larger Volvo models. This compact format makes the engine lighter. Combined with Volvo’s architecture – transverse engine installation – it also contributes to high crash safety.
The new five-cylinder, in-line engines have a displacement of 2.4 and 2.5 litres respectively. The five cylinders and large displacement provide high torque from low engine revs – along with swift acceleration.
The most powerful engine, the T5, offers a maximum of 220 hp and 320 Nm of torque. It can be combined with the same type of electronically-controlled All Wheel Drive as other Volvo models.
When it is launched, the new Volvo V50 will also be available with a choice of two five-cylinder, normally-aspirated engines (170 hp and 140 hp) – and an entirely new four-cylinder diesel engine (136 hp).
The turbo diesel has second-generation common rail technology featuring moving rails.
Transmissions from the R models
The six-speed manual gearbox developed for the Volvo S60 R and V70 R is now making its entry in the Volvo V50 T5.
The normally-aspirated engines are mated to a new generation of Volvo’s five-speed manual gearbox.
The automatic transmission for the Volvo V50 is the same as that used in the larger Volvo models. It is a five-speed unit with an adaptive gear-changing pattern; in other words, it adapts to the current driving style.
Chassis with the properties of a large car
The new Volvo V50 has been developed in the same spirit as the Volvo S60 and Volvo S80. The experience acquired from the advanced Volvo S60 R and V70 R formed the basis for the new sportswagon.
The five-cylinder powertrain laid the foundation for the large-car properties. Independent suspension with a multilink system at the rear provides a superb combination of comfort and consistent response. The wider track and longer wheelbase, compared with the Volvo V40, also contribute to the stable behaviour of the car on the road.
Discussion Starter #2
Another pic....
The dash board.....
