Can I convert my ANSI PST to UNICODE.I need help because I have no idea how to update ANSI PST if it were created by Outlook 97 to UNICODE.
You can easily Convert ANSI PST Files to Unicode PST Files format as well as your contacts and Calendar info with advanced Upgrade PST Software. By using this Software you can also Convert Unicode PST to ANSI format as per your requirement. The software enhanced with advanced conversion algorithm that supports batch operations to convert PST files.
visit here :mergeoutlookpst.com/upgrade-outlook-pst
Outlook files created with MS Outlook 97-2002 versions are ANSI PST files. MS Outlook 2003 & above versions offer greater storage capacity for Outlook items and folders. As there is no automatic way of converting a Microsoft Outlook 97-2002 ANSI PST to UNICODE PST. The easiest way to convert ANSI PST file to UNICODE PST by using Softaken PST Upgrade and Downgrade tool that the helps the user to upgrade PST file, it also has the solution for batch conversion of ANSI to UNICODE and UNICODE to ANSI PST.
