1 - 13 of 13 Posts
These wheels are in mint condition with no curb rash and scratches. All wheels are true and straight. We had them on for a short time, ~300 miles as my wife didn’t like the way they looked (too sporty). Here are some details on the wheels:
1) Wheel Manufacture and model: TSW Petrol Octane, 2006
2) Wheel Material: Aluminum Alloy
3) Wheel Diameter : 18"
4) Wheel Width: 8”
5) Lip Width: 2" (Stainless Steel Chrome Lip)
6) Bolt Pattern: 5 X 120 or 5 X 4.72
7) Wheel Finish: Hyper Silver
8) Wheel weight: 24lbs.
$750 or best offer
Discussion Starter · #8 ·
BMW wheels are Hub Centric. That means the center on the car using the hub. The center bore is the diameter of this hub which matches the hub on the car.
For most purposes, all BMWs except the E39 have the same center bore/hub diameter at 72.56mm. The E39 is a bit bigger at 74.1mm.
That said, if you get wheels from an E39 you will need hub adapter rings to fit the hub and the larger center bore of the wheel. They are available on ebay and other places.
1 - 13 of 13 Posts
