1 - 11 of 11 Posts
hey guys, as i was driving earlier the car decided to go crazy on me :wrench well it was running fine until i stopped at a red light, then after it went green i just pushed the pedal and soon as i reached around 30-40mph the car jus revved all the way up to 5-6k rpm and wouldnt add speed, just reving.... (as if it was on neutral) anyways a friend suggested it could be the sensor in the transmission thing (dont know much about cars ;( sorry) well anyways, this ever happened to anyone else or know what could be wrong??? well k thanks :cry
that sucks
did its start making any strange noises, b/c ive heard numerous stories of exploding gears, the tranny will usually start making a rattling noise after this.
you do have a manual right?
nope... auto :thumbsdown heh, well i can drive it if i put it in 1 or 2 but above that it'll just rev and not add speed, but i can drive it up to 30mph (guess thats when the gears suppose to change) and well ya it gets stuck there :( :wrench
Something similar happened to me just like your story but it was in my 91'legend cpe..auto. rev'ed pass 2-3k ish and does the same shit as yours...the transmission was bad, had to replace it...roughly 2grand...imagine you having a BIMMA....prolly cost you your left eye, or right foot? lol....???how to fix? I suggest getting the tranny looked at.
ah damn dont wanna lose me left eye! :blink: lol friend of mine said same thing happened to his intrepid, and it was just the sensor... ahh im hoping its just that! hehe damn costly repairs :pissed2
my friend had that happen to his oldsmobile eighty-eight, it was just a sensor, only cost him about 40$ or so i think...
i took it in to the shop and the mechanic started telling me i may need a transmission rebuild yada yada :help then he test drove it and he said it seems fine so he hooked up a computer and its something about incorrect gear ratio thing :dunno then i mentioned how i got new bigger wheels and he said ah it could be that cuz the speedometer is reading slower and such... ahh mann this sucks :wrench
Discussion Starter #8
hmmm i wonder if is it because of the shark injector, ill try to reset it to stock and run the car to see if it'll fix it and just re-install later, hmm anyone who chipped their car did this to them...???
be very very careful!! Check if the transmission fluid needs renewing. It must NOT be dirty at all. Generally Beemer engines are designed to work with a load. If the engine is revving too much with little load, its not too good for the engine ive heard.
modern transmissions shouldnt really go cos they're computer controlled. There could be a bit of a problem with the computer tho
Most likely a valve body issue. You can have the valve body replaced by a competent shop but you take a chance that a clutch pack may have been affected by the slipping. So after paying for the valve body replacement, you may end up having to replace the whole trans after all. Then you've spent more money than if you had just replaced the trans to begin with. Depending on how many miles are on the trans and how long you plan to keep the car.. you can decide, but I would make a decison fast and not drive the car anymore.
Discussion Starter #11
damn :pissed2 i took the car to the dealer and paid the 150 deductable, then hours later they called and said the guy from :guns heritage (extended-warranty) need to take a look at first to see if they'd cover it :( and the dealer wants to drop the tranny for $500!!! they better cover it :( or the $2800 i paid for the extended warranty would be completly useless :banghead (just thought id share :cry )
1 - 11 of 11 Posts
