1 - 10 of 10 Posts
I am thinking my car has traction control because i want to be able to do a brakestand but the tires aren't spinning. Does my car have traction control? If so what cable do I cut to turn it off?
brakestand.??? huh?
do you mean torque braking before a launch? if so, i dont know if your car has enough power to do a decent sized peel out with the auto tranny. i'm not saying its weak, but my dads gs400 with a v8 and 300hp can only get a a short scattered peel out whenever i torque brake with traction off.
theres a chance your car has a LSD, although its not too likely since you have a automatic
Discussion Starter · #5 ·
I was trying and it seemed liked the differential was just slipping.....the tires were chirping a little but not much......I seen a really good brakestand in a stock VW beetle......and i have more power than that......
i don't know if autos have it. there may be an ASC or ACS (i forget) down between your shifter and stereo. if you turn that off you can...but i think that is only in standards. besides...it's bad on your tires and car.
maybe the beetle was a 5speed
... gah... dummy
Beetle is FWD and 1 wheel drive or open diff for non lamens
on an auto e46 im not sure about e36 you CAN'T rev the engine while in "N" and drop it to "D".....
the e-brake doesn't work either.
Discussion Starter · #10 ·
I can push the little M on a button next to my shifter and drop it into first and rev it while holding the brake and it will chirp some but thats all.....then i can rev it up to as high as i want and push it forward into 2 then same then to 3 then same then to D which is 4 and i can dust a 98 mustang gt v8 5 speed......
1 - 10 of 10 Posts
