my oil change is comming up pretty soon......i need to bring it in to check the seals to make sure it can handle syn but the question is....how do i know which filter i have ? one has plastik the other has metal.....also how tight do i put the filter resevoirs cap back on and is there any special things that i need to be sure of before i change the oil? thanks
i heard you should only tighten the filter cap hand tight, but it wouldnt hurt to give it a twist or two with a wrench or something. as for the oil weight, i'm not sure, it depends on your climate, just ask your mechanic what he recommends.
no lower than 91 octane buddy
Discussion Starter · #5 ·
thanks to all.....yeah 91 is what i thought too.....also....ti check see if i have the plastik or metal filter..should i open the resevoir to check or will oil and debris flood the engine and the garage floor?
thanks
i dont think oil will come out if you open the filter reservoir...mayb a little bit
