1 - 14 of 14 Posts
right?!?!?!
"THIS IS A NICE SET OF FOUR BMW 17" RIMS WITH LOW PROFILE TIRES BRIDGESTONE 245/40 ZR17 ON THEM. THESE CAME OFF OF HIS 2000 323 BMW AND WOULD FIT ANY 3 SERIES. "
IS HE RIGHT??? CAN I GET THESE??? they're beautifuL! (*sniff*)
http://i13.ebayimg.com/01/i/00/7c/81/e6_1.JPG
M3 E-36 (94 +)
318 E-36 (92 +)
318TI (96 +)
325 (92 +)
328 E-36 (92 +)
Z3 Roadster (96 +)
Wheel Size l Bolt Pattern l Bkside Off Set l Hub Bore l Suggested Tire Size
.....15x7.........5x120 mm.......+35 mm...........72.56...........205/60x15
.....16x7.........5x120 mm.......+35 mm...........72.56...........225/50x16
.....16x7.5......5x120 mm.......+35 mm...........72.56...........225/50x16
.....17x7.5......5x120 mm.......+35 mm...........72.56...........225/45,245/40x17[R]
.....17x8.........5x120 mm.......+40 mm...........72.56...........225/45,245/40x17[R]
.....18x8.........5x120 mm.......+40 mm...........72.56...........225/40x18
WARNING: Sizes 15x7 through 16x7.5 will not work on 1997 & newer M3.
Conversion Chart MM to Inches
...MM l Inches..... l MM l Inches
95.25....3.75......120.00 4.72
98.00....3.86......120.65 4.75
100.00..3.94......127.00 5.00
101.60..4.00......130.00 5.12
108.88..4.25......135.00 5.31
110.00..4.31......139.70 5.50
112.00..4.41......165.10 6.69
114.30..4.50......170.00 6.50
none of that stuff is listed man please i'm new i joined the forum a month ago. have NEVER been this into technicals with cars. Please just give me a yes no on #1 and #2, and which you like better
I like #2 better but they won't fit on your car. #1 will fit for sure but you need to know what the offset is... :thumbs
Discussion Starter #6
how do you know 2 won't fit, and how do i find out offset for #1?
#1 will fit. no prob
#2 will not because they are OEM for the e46 m3. There are replicas of those that will fit an e36 and 346, however the OEMs will only fit the M3.
go with number 1. like stated above the OEM M3's do fit but not without a lot of extra work. so in other words dont bother .
Discussion Starter #9
if i can get em for 500 is that a good deal? they look like they'rein good shape. WITH tires.
sounds resonable. I got my optional OEM 325 rims and tires for 390 shipped after both rims and tires were destroyed on the right side of my car.
picked these up with 95% of the tread remaining. Little rash but not bad.
how much you want for the rims anyways john
1 - 14 of 14 Posts
