does anyoine know how to take the airconditioner vents out of a 02 325ci dash so i can stick a streetglow light in there? and also has anyone in this forum put a sreetglows on ther car? i need some more i dieas to make it look NICE. :driving
Uh, warranty? If anything goes wrong after the install the dealer will rape you on the warranty.
Why the vents?
if I remember correctly, the dash pad has gotta come out. Damn it, if I only had a pic in front of me it would jog my memory. Forgive me but it's be a little while since I've removed one.
instructions on how to remove the air vents.
Left or driver's side vent
1. Pry gently at the dashboard trim to remove.
CAUTION - to avoid marring interior trim, work with a plastic prying tool.
2. Remove air vent mounting screws.
3. Lift vent slightly and withdraw from dashboard.
NOTE
* Removal of right or center dashboard vent is similar
* To fully remove the center dashboard vent, use pliers to detach control cable housing and remove from control lever.
* Remove trim on right side prior to removing center trim.
4. Installation is reverse of removal.
i wish i had some pictures to show you, but i hope this helps.
you're right, I was thinking E38 center vent. See, it just took a little jogging of the memory. Now I almost wish I was still a tech.... nah :nope
I guess I'll just have to go buy one of each model to keep on hand. :screwy
