Vendor
Ensure that your European car is able to handle everything that the road might throw at it and improve braking performance with the Euro-Stop Premium Plain Brakes by Power Stop.
The complete Brake Kit consists of the ECE-R90 certified components crafted with the OE specifications of your vehicle in mind to prevent brake judder, increase the contact with the road surface, and offer the quietest braking. The best-in-class Euro-Stop brake kit comes with a set of pads, rotors, sensors, and mounting hardware for easy installation.
Power Stop - Euro-Stop Premium Plain Brake Kit
Rotor Benefits:
  • Perfect for non-aggressive driving
  • Ensure quiet operation
  • Offer low dust and long pad life
  • More resistant to warping or cracking
Features:
  • Improved braking safety and performance
  • ECE-R90 certified components for your European vehicle
  • Optimal thermal conductivity
  • Helps prevent brake judder
  • Better damping coefficient for quiet braking
  • Higher resistance to distortion and thermal cracking
  • High coefficient of friction for increased performance
  • Genuine Geomet™ 360 brake rotor coating
  • Rotors machined to OE specifications for quiet, smooth braking
  • Brake Pads are road-tested 200 000 miles
Follow this link to read more about the new Power Stop product.
Rotor Benefits:
Features:
When you put high miles on your vehicle, you will need to replace some things sooner or later. Be prepared to change out parts and stay on top of the normal wear and tear. Eric advises just keeping an eye on basics like the gas mileage. If you notice a change, it’s time to check out what could be wrong. “Fixing something before your car breaks down is usually going to be less expensive,” he says.
https://www.signaturedetailers.com/
Keep your car from getting damaged. That means driving defensively – look out for other cars, potholes and bumps. And to see those road hazards, your headlights should be clean and bright.
“If you look at the cars on the road, you’ll see headlight lenses that have turned yellow,” says signaturedetailers“Most people don’t realize that you can fix that yourself.”
