1 - 13 of 13 Posts
How would you go about doing that? The guy I bought my car from stuck an M3 emblem on the back of the car when it's really a 325is
You need to get a heat gun to slowly heat it, then it will pry right off. Don't use a blowtorch or some shit like that, it will burn the paint. Try a hairdryer on low if you don't have the heat gun. Your best off going to an autobody shop though. It will only take them 5 mins. Plus they will have the rubbing compound and finish glaze so there will be no traces. Good luck. Check mine
I am Teh Edumacator.
When it was 85 degrees and sunny outside on my black car, I used dental floss and a solvent to remove my old 528i emblem on my last car. Worked like a charm.
1 - 13 of 13 Posts
