My taillights won't work on my 1989 325i. The fuses are good. Any recommedations? :confused
you get a warning light on the above head indicator? And are you certain the fuses are good? Theres a left and a right fuse.
I think the fuese are good. I swapped them around with some others that i thought were good. I do get a warning light lit up.
check all the bulbs and dont forget to check the emergency or whatever brake light in the rear window.
I checked the bulbs and they were good. I didn't check the window brake light. Are they connected? I just realized that they are connected to the brake lights, which work. So that can't be part of the problem.
