i cant remember if it was e46 or 36, but his motor seems to work fine becuase it tilts, id say its the switchOriginally posted by AZ325Ci@May 21 2003, 08:23 AM
i don't have any problems with mine.
have you tried looking at the motor?
i cant remember if it was e46 or 36, but his motor seems to work fine becuase it tilts, id say its the switch [/b][/quote]Originally posted by SpeedsterBMW+May 21 2003, 06:24 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (SpeedsterBMW @ May 21 2003, 06:24 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin--AZ325Ci@May 21 2003, 08:23 AM
you could be right. [/b][/quote]Originally posted by AZ325Ci+May 21 2003, 08:26 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (AZ325Ci @ May 21 2003, 08:26 AM)</td></tr><tr><td id='QUOTE'>Originally posted by [email protected] 21 2003, 06:24 AM
i usually am! :lol: [/b][/quote]Originally posted by SpeedsterBMW+May 21 2003, 06:27 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (SpeedsterBMW @ May 21 2003, 06:27 AM)</td></tr><tr><td id='QUOTE'>Originally posted by [email protected] 21 2003, 08:26 AM
you could be right.
:huh: <_<Originally posted by AZ325Ci+May 21 2003, 08:32 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (AZ325Ci @ May 21 2003, 08:32 AM)</td></tr><tr><td id='QUOTE'>Originally posted by [email protected] 21 2003, 06:27 AM
you could be right.
i usually am! :lol:
yea, pull the panel down, and check the connections....Originally posted by Scarface@May 21 2003, 09:34 AM
thanks for the help guys, i will try to hold it down some if not could there be any cables in there broke? is there even any cables in there??
At least yours semi-works. I haven't used my sunroof for 3 years! :blink: :f-uOriginally posted by Scarface@May 21 2003, 05:55 AM
in my 92 325i, you can vent the sunroof but thats all it does, it doesnt open any more than that...what could cause this?
At least yours semi-works. I haven't used my sunroof for 3 years! :blink: :f-u [/b][/quote]Originally posted by BMWg84+May 21 2003, 01:28 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (BMWg84 @ May 21 2003, 01:28 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin--Scarface@May 21 2003, 05:55 AM
After you first open it hit the same button again and it'll open a little more..Originally posted by Scarface@May 21 2003, 07:55 AM
THATS the problem i was talking about, it "forgets"Originally posted by woobiee@May 22 2003, 09:12 AM
maybe the sunroof problems are in the E46 as well...hope they are the same. On my E46, the sunroof sometimes forgets where it is. Ok so when the sunroof is closed and sometimes when I try to open it, it wont. To solve this problem, is to hold the button to close and hold it there for 5-20 seconds. Then everything should work out.
Right now, my slide cover for my moon roof is broken. The tabs broke and now it is all over the place and off track. Sometimes when I open it or close it, it wont because it gets stuck with the slide cover. So when this happens, I gotta open it slowly, or pull on the slide until its back on track. Im finally back from school and next week im sending my car to the dealer to repare the sunroof under warranty.
