Disregard my previous post, I solved the revving problem on my own by replacing the cap and rotor. However, the car still has trouble starting. It has new plugs and I'll buy new wires tonight. I used to be able to turn the key and the car would start immediately, now it requires holding the starter on for longer, and when its stutters on initially, it will stumble off right away. After doing that 5 times or so, it starts as if nothing was ever wrong and the idle adjusts to 900rpm. I know its not a big problem does anyone in this forum know these older cars?
