1 - 12 of 12 Posts
Split PST Tool can select the PST file of large size from any location and divides it in several PST files of small sizes. It uses its own PST splitter to avoid the risk of corruption of PST files due to the issue of being over-sized. It also divides large PST file into manageable and smaller PST files as per the specific criterion like size, date, folder and email id, and protects them from any corruption issues because of file size limits.It also supports all versions of MS Outlook like 2000, 2002, 2003 and 2010 and is fully compatible to Windows 2000, Xp, 2003, Vista, 10, 8.1, 8, 7.
Get details visit to: http://www.undeletepcfiles.com/split-pst-file.html
MS Outlook doesn't have a built-in function to split a .PST file to make the size smaller and manageable. Either you have to use "archive" feature to move PST items to new Outlook PST file or you have to "Move to Folder" feature. Otherwise, you can also use a tool for splitting large PST file: http://www.split-pst.com
Split PST Tool is an advance professional pst splitter tool embedded with a strong algorithm which can easily and efficiently split the large pst file into small pst files with the hundred percent accuracy of data.Split PST File Tool supports all versions of MS Outlook and is capable of splitting of PST files creates using MS Outlook 2000, 2002 (XP), 2003, 2007, 2010 versions.
Visit here:- datavare.com/software/outlook-pst-split-expert.html
PST Splitter
PST Splitter software is a very robust & powerful tool that helps you split large Outlook PST files into smaller files as per requirement.
Salient features:
Fastest and Efficient for this process
Splits PST files by Size, Date, Email ID, and Folders
Splits PST files into smaller ones and prevents corruption
Preserves the structure of original PST files after splitting
Supports MS Outlook 2016, 2013, 2010, 2007 & 2003
For more info visit: completeconverter.com/split-pst/
Mailvita Split PST for Mac File software is excellent utility which divides large PST file into manageable and smaller PST files as per the specific criterion like size, date, folder and email id, and protects them from any corruption issues because of file size limits.It is fully capable of splitting all MS outlook item such as folders, contacts, calendars, journals, email folders. The software makes you sure that no actual data deleted during the process.This software help the users to work with many versions of MS Outlook as well as it is compatible with different versions of Mac.
Split PST File software is excellent utility which divides large PST file into manageable and smaller PST files as per the specific criterion . This remarkable software help the users to work with many versions of MS Outlook as well as it is compatible with different versions of Windows. softakensoftware.com/split-outlook-pst.html
PST Split tool
If you searching for a tool which will help you to split large PST Files into smaller then this article will help you out in this there are some manual hacks and one of the best software for the issues. As we all know manual tricks are time-consuming and even data security is not there even a minor mistake can lead to data loss. so go with the tool-free demo version.
SysInfo PST Split
pst splitter
If you are looking for a solution to Spit your oversized PST file then here is the best way to split them. The Outlook PST Splitter is an excellent utility software which provides the option to split oversized PST file as per the requirements of the users. This PST File Splitter Software provides an option to split PST file by specific Date & Time range. You can download this tool at FREE of cost.
For more information about Visit here Outlook PST Splitter
ToolsGround Split Outlook PST Software is an advanced tool that breaks large size PST file into smaller PST files as per the specific criterion. The tool performs a risk-free operation for splitting PST without making any change on original data.
More Info;- toolsground.com/split-outlook-pst/
Hello
The KDETools Outlook PST Splitter tool is one of the best PST Splitter tool which easily divides large PST files into small parts by date, size, year and folder. It is easily capable of ANSI and UNICODE Version. This tool split the large PST files without installing MS-Outlook. It split the large PST files without any changing original data. It split the large PST files in all Windows Version and Outlook Version. It is 100% safe and secure conversation.
Hello
Last Month I have phased the same problem due to large PST files My Microsoft does not work properly then my friend suggests me to try the PST Splitter to is KDETools PST Splitter. This tool easily solves or split my large PST files into small parts according to my needs by date, size, year and folder.
To Split or Break large size Outlook PST files in some small PST files here you will get the excellent solution. To Split, your Outlook PST files in some small PST files use Gaintools Split Tool of Outlook which allows user breaks the PST file in some small PST files by Date, Size and access all them as according to the current requirement. To get more information about Outlook PST Split Technique. The free trial version which transfers the first 10 items from each folder.
1 - 12 of 12 Posts
