1 - 15 of 15 Posts
Festivus yes, bagels no..
I've searched for days and days about this but haven't come up with anything solid.
Problem: The self leveling headlights will sometimes level up to the perfect height, and sometimes they'll only level up to well-below the perfect height.
My thoughts: Both headlights ALWAYS move, move together, move equally, move at the same time, both either move to the correct height or they both don't move to the correct height....so, I think this rules out bad stepper motors or anything in the headlight itself.
That could mean that one or both of the leveling sensors on either suspension are going out. I checked the front sensor and nothing is visibly broken (the plastic arm tends to break). I even sprayed it with carb cleaner to hopefully clean it out.
There is nothing consistent about when they will go to the correct height and when they will not. They might work fine for days and then not quite work for a couple days. It could be every other use as well.
Any idea's or pointers?
I can't even find a place online to buy new sensors.
Any help at all would be awesome.
Thanks!
Kinda but not really. I pulled both the sensors and cleaned them with electrical cleaner but that didn't help at all.
At first the lights would sometimes level to the correct height and sometimes they would level waaaaay to low. After a while they started to ALWAYS level too low and NEVER leveled up to the correct height...so all I did was adjust the height of the lights so they level to the correct height. I didn't fix the problem but now I can see. They still level/move but not as much as they did before. Does all that make sense?
Hope that helps.
Hope that helps.
I am tempted to adjust the static aim too but since mine levels properly about half the time, I'm afraid they lights will be too high when they are in the correct position. I called up the dealer today and they want me to bring the car in for software upgrading - for the headlights???
I just bought a 2006 325 Ci convertible and I noticed that the headlights seemed to be pointed a little low or at least lower than my other cars. I ddin't realize that they were self leveling, mine don't seem to move any higher. Also is the red tailight area surrounding the backup (white) light supposed to light up, because mine is not.
I don't know if anything has been done as far as lowering the suspension, we just bought the car used at a BMW dealership. At last resort, we are planning on taking it there and asking about the headlights. Thanks for the info.
I'm having a similar problem with my e46's xenons. The difference, is that mine don't auto level at all. Someone suggested to me that perhaps it was retrofitted with them before I bought the car (and can't auto level), and I was fine believing that. But recently I came to the conclusion that they are stock headlights and even have the sensor passenger side suspension sensor (intact). So clearly, its supposed to auto-level, but I don't have the slightest idea why they don't. :dunno
headlight levelling problem
This is not a solution to the previous problem but asking for an answer to a similar problem I have. My headlights will auto-level if I have the manual adjustment set what is actually too high. If I reset the manual adjustment lower, the lights will get "stuck" trying to auto-level. If I put pressure on the rubber motor cover behind the passenger light the lights will eventually rise automatically. Seems something is just not catching properly in the motor behind the light? Any ideas?
1 - 15 of 15 Posts
