Improving your vehicle's braking performance is simpler than you might think. We offer EBC Brakes products designed to give you better stopping power, cleaner wheels, and a sleek look behind your rims. Whether you're into performance driving or just want more reliable brakes for daily use, we've got you covered.
Our EBC Stage 5 Superstreet Brake Kit is a top pick for those seeking high performance. It combines the USR BlackDash Sport Slotted Rotors with Redstuff Ceramic Low Dust Brake Pads. The slotted rotors help vent gases and debris, improving brake response and reducing the risk of brake fade. Paired with the Redstuff pads, you'll enjoy strong stopping power and less brake dust, keeping your wheels looking great.
If you prefer individual upgrades, the USR BlackDash Slotted Rotors offer improved braking efficiency and a stylish black finish that resists corrosion. The Redstuff Ceramic Brake Pads provide excellent stopping power with minimal dust and noise, making them ideal for everyday driving. We're here to help you find the perfect braking components to enhance your driving experience. Upgrade your brakes today and feel the difference on the road.
EBC® - Stage 5 Super Street Dimpled and Slotted Brake Kit
Note: Choose your specific model in "Product Options"
Features:
- Angled slots on rotor surfaces allow superior expulsion of heat, water, brake dust, and friction gases
- Round indents in the rotors surface further increase cooling without the risk of cracking that drill-through holes pose
- Black GEOMET™ and NITROTHERM™ anti corrosive finish
- Brake rotors are unidirectional to the left and right side of your vehicle to maximize effectiveness
- 3GD vented centers feature a wider aperture for air to pass between both rotor sides for superior cooling
- EBC recommends a 500-mile break in period with lighter braking application
- Designed to provide an optimum combination of street and racetrack performance
- Unique composition allows high braking friction when brakes are cold
- Features a cold friction rating of 0.5
- Backing plate and side edges of brake pad are yellow powder coated for resistance to corrosion
- Pad surfaces have chamfered edges to reduce contact against rotor lip that forms over time and causes squealing
- Center gap allows for proper heat expansion of brake pads
- Built in noise-reducing shims
- Provides equivalent performance to GG-rated brake pads
- Patented Brake-In™ red pad surface coating provides better grip during the first 100 miles after new pads are installed
- Patented Brake-In™ red pad surface coating scours off any existing glaze or heat spots from brake rotor surface for more even surface mating
EBC® - USR BlackDash Series Sport Slotted Brake Rotors
USR BlackDash Series Sport Slotted Brake Rotors by EBC®. EBC sets the highest standards for stopping power and offers the highly-efficient EBC brake rotors and pads for the active drivers who put safety first.
Features:
- Created to be the lowest noise brake rotors designed for performance applications
- Recommended by EBC for use with Greenstuff, Yellowstuff, and Redstuff pads
- Two sets of slots on rotor surfaces provide even pad wear which creates flat, parallel rotor wear without ridges from developing
Benefits:
- Ensure increased pad bite and improved air circulation
- Clean and de-glaze pad surface for optimum pad coefficient of friction
- Create an escape route for debris, dust, and water
- Reduce stopping distances in wet weather
- Offer much faster heat dissipation
- Resistant to warping and fading
EBC® - Redstuff Ceramic Low Dust Brake Pads
Redstuff Ceramic Low Dust Brake Pads by EBC®. EBC sets the highest standards for stopping power and offers the highly-efficient EBC brake rotors and pads for the active drivers who put safety first.
Features:
- Superior ceramic pad compounds resist heat buildup, dust, and squealing
- Ceramic pad compounds wear slower and last longer than OEM equipment
- Ceramic pads eliminate squealing under the most extreme cold or hot temperatures
- EBC lowest dust fast street pad with 15% brake improvement
- Capable of repeated heavy brake use without brake “Fall-Off”
- Very minimal disc or rotor damage characteristics
- Superb material for Prestige imports European and Asian cars
- ECE R 90 type approved for most cars
- Features red brake in surface coating for instant safe braking after install
- Sold as a set for two wheels
You can browse the full catalog of EBC brakes on our website:
EBC Brakes™ - Brake Pads, Rotors, Kits | CARiD
EBC sets the highest standards for stopping power and offers the innovative, highly-efficient EBC brake rotors and pads for drivers who put safety first.
