How can you reset the warning light on a 1999 528i (e39)? I want to change the oil every 5k miles not 15k miles as recommended.
If you do non-scheduled oil changes you should not reset the light as it is tied into the inspection settings also. You can jumper between a pin in the 20 pin service interface port and ground to reset the light. There is a diagram of how to do this in one of the FAQ sections.
Ben
