Hey, I just put a brand new pair of fog lights in my car, and they look awesome. I am trying to wire them up to my parking lights, so that it is like newer cars. I am not sure where to join certain wires together to make it work right, and don't want to short out my parking lights/headlights/fog lights.
Any information you can provide would be awesome!
first off this from a celicasupra forum(mk2 supra) i dont see why it wouldnt work on the bmw since wireing should be simalar but whith stuff pertaining to the mk supra like the dash removal u will just need to get a wireing diagram for the bimmer im sure somone else caan be more helpfull than me :thud
allso what wheels are those? they look sick kinda like audi 6 spokes
procedure was documented by Greg Giacchi
Procedure:
Here are my instructions for rewiring the factory foglamps on a Mk2 Celica Supra. I have performed this procedure on several 1984 and 1985 models, and have been told the wiring colors on the 1982 and 1983 cars are the same.
My method will allow you to leave the factory foglamp rocker switch in the ON position all the time. The foglamps will light up whenever the parking lamps are ON. However, you can still switch the fogs off if you desire. Please note my method will bypass the high-beam cutout. You will only need a Philips Screwdriver, Wire Cutters, common "solderless" Spade Connectors and Crimp Tool, Electrical Tape, and approx 24 inches of 12 or 14 gauge wire.
Start by removing the six phillips head trim screws from the center console. Two are on each side, and two more are inside the center compartment. Lift the console up, and turn over on its side.
Underneath, you will notice the foglamp switch has two wires feeding it: green/orange and red/white. The red/white is the hot side and will be eliminated. Cut this red/white wire leaving a 2 to 3 inch pigtail on the switch side. Wrap the source side of the red/white wire with electrical tape. You will now obtain power from the map lamp which is located under the armrest. This map lamp is actuated by the parking lamps. With the console still up-side-down, you will notice that the
map lamp has a white/black and green wire feeding it. The green wire is hot and will be the new foglamp power source. You'll want to splice in about 18 inches of either 12 or 14 gauge wire to this green wire. Then connect the other end of this new wire to your red/white wire pigtail.
TEST to make sure the foglamps are now working with parking lamps.
Reinstall console - you are done! REMEMBER to wrap the unused red/white wire (source side) with electrical tape to prevent shorting.
should look llike this on the supra
