The check engine light is not lit once the car is started. However if I put the keys in acc position, the check engine light is on. Is this normal or do I have to get this think checked?
Thanks in advance.
-J
don't --all-- the lights run a self-test when you turn the key to the position before "START"?
if your car is on, and any light stays on, there is a problem. If not, everything is fine.
Wlaker is right; all the lights should come on when you first turn the car on. It's basically a "lamp test" feture so you know all the lights are working correctly.
-Brian
