Does anyone have an experience with BMW alarm in 330Ci converible? Today dealer installed (at least told that installed :) alarm kit and activate by reprograming OBC. According to dealer there is no volumetric and shock sensor for converible, tilt sensor only. But I liitle bit curious: I tried to swing my car very hard but armed alarm was not tripped. Hmm, I can easy remove the wheel with much less disturbance. Either tilt sensor doesn't work or...?
woobiee, thanks for explanation... 5" is a lot.
When you mentioned "aftermarket shock sensor" don't you have anything particular model in mind? It it connector-compatible or I should make some kludge with wiring? thx!
woobiee, thank you for advise. Yes, I found couple vendors on the Web.
Where in your car did you put this sensor? Is an any idea where to connect it?
Thx, mlk
