power seat trouble`
1877 Views 3 Replies 4 Participants Last post by  triggrhaapi
My passenger side power seat wont go up as in recline to unrecline... the motor is probably not burned out because it still makes the same noise... Could it be a loose wire? anyone know? If its totally fucked im gonna go for some new seats which could be cool...
i assume you checked to make sure nothing is blocking it or holding it up.
all i can think that maybe wrong is that there is a problem with the motor. sure it may make a noise , but if its not moving , maybe something is broken like the leveling device.
i dunno does the other functions work?
I would be willing to bet that it is the white nylon gear is broken. This is the exact same thing that happened to me. I would engage the button to recline the passenger seat and could hear the motor run, but the seatback would not move. I took the seat out, removed the rear motors and took the cover off a small gearbox. I discovered a small white nylon gear was broken. The BMW dealer does not sell a replacement gear and could not find one in a salvage yard. Luckily, I posted my problem on another message board and someone responded. He took the initative and had new gears custom machined out of bronze. The cost was about $80 and the fit was perfect. Also, I will never have to worry about the gear failing again. However, there are a total of 4 of these nylon gears (2 in each seat). I would suggest removing the good gear and contacting a local machinist to see if they can duplicate the gear.
BMW doesn't even sell the gearbox? Who makes the seats that BMW uses?
