Does anyone know if parts are interchangeable?I have a 2000 528i (e39) that was in a wreck where I need to get new axles. I was going to pick them off of a 2000 525 but I am not sure if they will match. Can someone help? I don’t know if it makes a difference but the 525 also says it is an e39
Vendor
Hi. Both 528i and 525 are E39, as well as 520, 523, 540, etc. Yet the same body code does not make these vehicles are the same. In this case, the axles will be different, If you are looking for a good deal on the axles for your 2000 528i, I can suggest you checking out our selection of 2000 BMW 5-Series Axles. In the product options dropdowns you will need to select 528i to get the right axles. Hope this helps!
