1 - 20 of 22 Posts
As you can see from the picture below, I have a little more cleaning to do to it before I start. I'm thinking about taking a 1/4 sheet electric sander and danding down the horizontal lines along with the BMW insignia.
Note: Do not Sandblast/Beadblast your cover. If any grit gets in under the tin splash shield, chances are you will not be able to wash it out thoroughly. However, the nice hot oil circulating through your engine certainly will dislodge the remnants and circulate them through your engine leading to premature failure.
As far as the paint goes, I'm thinking about using the Harley Davidson Black Crinkle Paint. I've seen examples of valve covers that used this paint on ebay and I thought they turned out great. IMO, I think it looks much better than the glossy black.
Before I apply the paint. I am going to give it a good cleaning with some simple green. After that I will start to apply the paint. I'm not to sure how many coats I will apply, anywhere from 4-7. After I'm done painting, I'll put the valve cover into an oven for a little bit (@ whatever temp. & however long the directions on the car say). After I remove it from the oven, I will wet sand the raised areas. That should give it a nice clean polish.
I'd like to hear from you if you have any helpful advice about painting valve covers.
this is engine enamel brand Flat black.... I bet i paid less and looks just as good
ehh that last picture was big
ss
Looks good.
How did you get the paint off of the raised areas?
Hand dremel tool using various bits at different times to take off the first layer then polish
can't you basically swipe a peice of sand paper over that and it will take away the paint on top? since its raised just sand it off.
yea but that will only show the brown metal beneath it
You have to scrape away the top layer of metal to have it shine and after your done you have to spray on a engine enamel clear coat so the exposed metal doesnt corrode since its aluminum.
Discussion Starter #8
That's what I was thinking.
Supposedly, it doesn't turn out as nice when you use sand paper on it (this is what I've heard). On the other hand, if you use a dremel or mill bastard file on it, it will look really good.
hehe im working on the intake mainfold and did the Valve Cover already ill put a pix later , but i used sand paper about 40 grit and 80 and 150 to finish, used a dremel tool for the ridges, and i got a chrome finish, but on my intake manifold i'm using an air compressor powered steel brush :) ill post those pixs too ..
Originally posted by detour54+Dec 10 2003, 02:27 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (detour54 @ Dec 10 2003, 02:27 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-lilboi@Dec 10 2003, 03:22 PM
Supposedly, it doesn't turn out as nice when you use sand paper on it (this is what I've heard). On the other hand, if you use a dremel or mill bastard file on it, it will look really good. [/b][/quote]
That's right. When I did mine for my previous 325is, I started off with sand paper and ended up scratching a bit of the paint off of the valve cover, close to the raised section. I then switched to a Dremel and it turned out nice.
this is how my valve cover came out, used sandpaper to shine up the raised surfaces.
Discussion Starter #13
Originally posted by pogiboy9@Dec 18 2003, 07:03 PM
ill post mine later, but i didn't paint my valve cover just polish the intake and the cover
Still, the polishing should look pretty good.
detour54,
we have the exact same valve cover. i don't see much of this type of cover around. what year model is your e30? would you mind posting a pic of the engine? i'm hoping it's the exact same engine as mine. i'm having a hard time looking for references on my m20 L-jetronic.
Discussion Starter #15
Originally posted by e30 dude@Dec 31 2003, 08:50 AM
detour54,
My E30 is an '86 325es. And no, I won't mind posting a picture of the engine. I will do so later on when I can find a pic of it on this computer.
Discussion Starter #16
I had some time to work on the valve cover with my recent scedule. I didn't do that much, but I got the raised parts looking good. I'm going to stop at a local Harley Davidson sometime early next week to pick up a can or two of Black Crinkle Paint. I still have a little cleaning to do before I apply the paint. What do you guys think about sanding down the entire surface to give the paint something to stick to?
And yes, that's a brand new dremel in the backround.
Originally posted by e30 dude@Dec 31 2003, 07:50 AM
detour54,
detour54,
here's a pic of my engine. my car a is 1983 320iA euro version. is this the same as yours? notice the many hoses coming out of the intake plenum, above the valve cover, the radiator with no filler cap, the different throttle body, etc.
anybody know exactly what engine i have here?
here's the link for a better view..
http://www.imagestation.com/picture/sraid9...44.jpg.orig.jpg
Discussion Starter #18
Originally posted by e30 dude+Jan 5 2004, 06:58 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (e30 dude @ Jan 5 2004, 06:58 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-e30 dude@Dec 31 2003, 07:50 AM
detour54,
detour54,
http://www.imagestation.com/picture/sraid9...44.jpg.orig.jpg [/b][/quote]
It's not the same as mine. I have a US '86 325es.
i shuda taken pictures of mine when i did it...
get a wire brush attatchment for your drill, screw it to your bench, polish the whole thing to shiny aluminum. wash it, mask the bottom (gasket surface) filler flange and breather holse flanges. then paint, use a bunch of coats. let it dry too. (i used flat black bbq grill paint, and it looks the ball!s) use sandpaper a little to get a better idea of what you have to grind, then use the dremel (or in my case the b&d wizard)
1 - 20 of 22 Posts
