Blue/Brown & Blue/Red wires on a connector...The plastic panels (the fender liners) are gone on both sides and no sign of any wires to be seen anywhere.
I don't think so. If u study the electrical circuits, the OAT circuit begins and ends in the instument cluster. Therefore, no bearing on the engine performance.There are no wires whatsoever no connector!! The display shows Temp is -40F. A mechanic told me this goes into the computer and that may affect the engine (timing,fuel-mixture) although it runs just fine.
P.S. We have +100F here in Tucson.
Thanks a lot! You seem to know everything. I have the Chilton manual and try to find the OAT circuit. I can live without the OAT, although nice to have.
the instrument cluster communicates with the engine module over the Can bus and I have seen the exterior temp sensor when it reads -40 degrees cause a service engine soon lamp to come on and a fault code stored in the DME. It depends on the year and model and DME variant though.I don't think so. If u study the electrical circuits, the OAT circuit begins and ends in the instument cluster. Therefore, no bearing on the engine performance.
The DME/ECU brain has it's own temperature sensor that gets it's signals from the engine, along with air temp measurements from the Mass Airflow meter... definitely not from the OAT
