1 - 1 of 1 Posts
Hi. Reading the manual I think it is a bit unclear whether this lamp (oil level warning) is supposed to flash along with the Serviceindicator? When I start the engine the light flashes. It keeps flashing two times AFTER the serviceindicator goes out. I have checked the oil level several times, at different temps. but it is exactly where it should be. This morning I noticed that the engine was running a bit warm, oil temp upwards of 100 degrees (Celcius). I think it normally runs at about 75 degrees. What could be wrong?
1 - 1 of 1 Posts
