1 - 1 of 1 Posts
Hi,
I can't get the oil quantity light to go out. I pulled the sending unit and checked it with a meter and it seems to work ok. In the event that the unit was bad, I replaced it with another one and the light still will not go out. I tried jumping the plug, like you can on the other sensors, still no luck. Also the charging indicator light will not come on when the ignition it switch on. Any thought out there on these two unrelated problems. Thanks
1984 325e
1986 325
1 - 1 of 1 Posts
