I went to work today, parked the car, it was hot today 90 F degrees..... the air conditioning system was working fine...
I came out of when I went to start the car I noticed that the Air conditioning was not working. There was no air coming out but the display seem to be OK.
I increased the air flow and NOTHING. No air flowing, shut the system down, turned it back on and nothing....This never happened before, I drove the car home, everything worked fine, the display of the system is fine, but NO AIR, (HOT nor COLD)....When you turn the AC/Heater ON/OFF, you can hear the motor change speeds...Like it always did...I believe this is normal...but again NO AIR...HOT nor COLD....
Any help would be appreciated, thanks
GREAT WEBSITE!!! (By the way...)
