1 - 14 of 14 Posts
ok so im having problems with my number four cylinder.... its not getting any fuel there fore not firing. we tried new wiring harness new coils new injector everything... still no response. a friend thinks it may be a computer problem has anyone ever heard or seen this and can help????
Very odd what colour was the spark plug when you removed it....
Oh, Hai there and welcome back darkhorse737 :)
hello witeshark. thanks. it is good to be back... workload has gotten the better of me and has eaten away my bimmerwerkz time :(
looking at all the posts i now feel disadvantaged :p am kinda slow to think and rusty on bimmer knowledge now, but i will get back into the groove soon enough ;)
I hope you are well :rule friend :)
42, The meaning of life
Does your #4 injector fire at all, you can hear them firing by getting a mechanics stethoscope, or putting the pointy end of a screw driver on the injector and the handle end in your ear. There should be a very clear click each time it fires, compare it to the sounds that the other injectos are making as a reference of what they should sound like. If it is firing, then check your spark by getting a spare spark plug (old one will do) and connect that cylinders lead to it, rest the plug body against a metal part of the car and then start the engine to see if there is a spark being generated. If you have a good spark and the injector is firing, then you either have a bad spark plug or some sort of fuel delivery issue to the injector. Good luck
Discussion Starter · #10 ·
yea we tried a few different techniques and its not even firing. but my cylinder issue has kinda been placed on hold seein how my thermostat died today and one of my belts broke...does anyone know if the alternator, battery and fan all work off the same belt???? this is an e36 325i 1992 by the way. my boyfriend thinks they are all on the same belt because my steering is very tight and my battery light has come on since the issue tonight
bummer.
well at least those issues are easy to identify and resolve (hopefully).
when you say its not firing, are you referring to the injector or spark plug?
Are you able to check out the injector signal with a multi meter?
single serpentine belt drives alternator, water pump, and steering.
I do not think your thermostat "died"... the what it is is that your waterpump stopped working when ur belt broke. ;)
we ran diagnostics on it and it showed nothing with the cylinders the only major thing that came up was the thermostat is going. and the plug looked brand new when we took the coils out.
plug looking like brand new... and dry suggests injector in that cylinder not working.
you can check the injector wire for contact and maybe pulse; and if that checks out, then it is a failed injector
plug looking like brand new but wet that would either be a bad plug or a bad coil. ;)
if all the above does check out, then the final stage in the DME went bad - a new brain will be the only solution in this case.
listening to the injector clicling dosent mean its working half of the time
1 - 14 of 14 Posts
