I just performed a clutch job on my son's 1995 318ti. We replaced the plastic pivot pin, clutch assembly, master and slave cylinders, and hydraulic lines. Our problem is that the clutch grinds when going into any gear. Once in gear and the clutch is released it drives fine and does not seem to slip. Did we not bleed the system well enough, or is there something misaligned in the clutch assembly. To me it seems as if the clutch is not being disengaged enough by the slave cylinder. We have tried all the bleeding procedures we could find on this forum, and the pedal seems firm enough, but still grinding when shifting.
Thanks in advance for any helpful suggestions.
