Hi,
I have an 83 323i. Drove into garage last year. Now with a fresh new battery, no crank, no lights. Absolutely quiet. Fusible link? If yes, where is it? or replace all relays in engine fuse box?
Thanks for your help!
Thanks. I actually found the problem. That model year has a small red accessory wire connected directly to the battery. If that is bad or not connected, car will not start, crank or lights. Can you imagine what can happen if a jr mechanic or novice fails to reinstall that wire. LOL. Mine had a loose connection on the connector itself which was shrink wrapped rubber. When I wiggled it my windows went up and best of all I could start the car...
