It is bloody cold here now and my 1995 318i would not start up last night when I tried to leave from work. I had the engine block heater plugged it, but I think the electrical outlet was faulty, so engine was dead cold in -35 C temps. I was able to stretch my extension cord to reach a functioning plug in the meantime, hopefully the engine will be warmed up today. I was going to get a battery boost from another co-worker, but I broke the hood latch handle, so now I can't get under the hood.
Can I safely try to get my car started by directly boosting the battery in the trunk, and what should I avoid doing that could damage some of the car's electronics?
There shall be no problem.
By the way, you may want to resolve the hood latch issue, as it is kind of important to get in there occasionally.
That procedure should be ok. As for that hood latch, check the position of the latch attached to the hood. I found mine was very hard to open and needed to adjust the position of the latch.
