1 - 10 of 10 Posts
Hello,
hope you like my car and provide me with all of your knowledge to make it better :eek:hnoes
well its a cosmos black 2.0L engine with 150hp (i think only 70hp are left from them:shifty) and i tried to tune up the engine a lil bit but i have no idea how, someone told me to go NA (whatever that is) and avoid turbo and supercharges if im planning to keep the car for more then 3 years.
so i went and bought my self a K&N filter and 2 Magnaflow mufflers and a two plates clutch but still no performance was added to it (only amazing mufflers soundtrack).
So guys any idea what should i do with it????
OK - for now you have a shiny black Z3 that's all show & no go. I see blacked out tails,a nice clean front end and interior, a trunk totally full of subs and ampage and word of big mufflers and a cold air intake. For a 2.0L engine - you have few options if you are looking for increased power besides forced induction or "FI" which on fact does mean supercharging or turbocharging the car. "NA" means "naturally aspirated" - that the engine is basically getting air on its own as designed, without and device forcing extra air into it via FI for additional power.
To get more power, you can either do some expensive modifications to your own engine with only modest power gains like new headers or boing it out bigger, or go FI. One other solution is to swap out your 2.0L engine for a bigger more powerful one that is NA like one from a 3.0L Z3 or perhaps a Z3-///M or ///M3's S54 3.2L engine. The cost effective answer is to add a supercharger - which uses incoming gases and forces them into your exisitng engine to increase it's power. This can be done with a nicely tuned chip for your specific engine that helps preserve drivability and the life of your engine. A turbo is more expensive, gets more power, and uses the outgoing gases from your engine being forced back onto it to boost power (this is why FI cars are said to have "boost"). Again- a supercharger is more amenable to your BMW and it's linear power curve and is less $$. If you do employ FI though - you will need to upgrade your brakes, suspension and likely your clutch kit to match so we are talking about an investment here - it just depends how badly you want more power and how much. It sounds and looks to me like you want a noticeable power gain you can really feel in the seat of your pants. If so - it means one of the options I listed. Again, depending on your budget and needs - you have to choose the best fit for you and your Z3. I went with a Supercharger as you can see and liked it a lot, although now I would go for a turbo as my tastes have changed to the more expensive and needs to the mote powerful. In a perfect world I would take the engine out of a 2001 or 2002 Z3-///M and supercharge it. Far more reasonably & keeping plenty of life in your car - I'd get a Dinan supercharger or one tro Active Autowerks. I'd try and stay away from VF Engineering (that's what's in mine - look up other threads on Bimmerwerkz or that discussion. I hope this helps you. Best of luck and enjoy your beautiful car!
Thanks alot mate for the info,
i went today to ask about M3 used engines but the prize was like it came from hell around 2600 to 3000$ for a 3.2 1996 - 1998
supercharge was around the same prize of M3 engine!!!
but then those people hows selling these thing told me that the turbo is the cheapest and its around 1500$ only!!!!
but i feel like buying the M engine coz what i know, turbos are not that good in hot areas of the world like my country.
so im going for the M engine so is the model 96 - 98 are good or they have issues that i should look for before swapping my tiny engine??
///M engines are good engines - just make sure you have it checked, the model # starts with the letter "S" like "S54" and try and match the year of your Z3 to the ///M engine being used in it. Good luck! Also, start thinking better brakes and suspension as more power needs to be stopped too..!!!
Discussion Starter · #6 ·
ok will do,
and about the suspension i have the stiff ones the they will be fine, and the clutch is sportesh as well all i need is as u said better breaks and the M engine.
btw do i need to buy M ECU or mine will do fine for it...
sorry lots of question....today i will buy every thing so i dont wanna forget anything!!
once i finish swapping i will try to put a clip & some pics....
Try the suspension you have but you may want coilovers and to lower your car. You can also look at better bushings and sway bars and X-braces for suspension. Need a big brake kit for sure..(Brembo is best and 4 piston is all you need really). And yes, with the new engine I'd say you need your ECU remapped so definitely get a chip and get the car tuned right! Good luck!
1 - 10 of 10 Posts
