Hello
I have a window problem wth all my windows ..the switches are not respinding when i try to put the windows up or down ...i checked all the fuses they are ok even changed fuse 48 and 49 ... is there any other fuse that controls this function or sum hidden button on the dash board or steering...
Please help as one of my windows is otally down
Regards... Dj magetsie
Have you ever thought about the fact that your window lifter is broken? This is the most obvious reason, but for some reason you did not specify it. Can you please check if my theory is correct? You can easily do this with the help of a diagnostic tool. If the power windows still turn out to be broken, then you can find out more information about them on the website http://www.cararac.com, I myself often use this service, as there is a huge database of cars and you can easily find exactly what interests you most! I hope you can solve your problem without serious investment, good luck!
