1 - 1 of 1 Posts
Before I spend 50 dollars on a new mirror switch I would like to know if anyone else has had this problem: Both left and right will not adjust. I checked the fuses and they were good. I removed the switch to check condition of the wiring and connection and it was good. The right motor works because it still swivels down when you put it into reverse. Any Ideas? Or should I just spend the 50 dollars on a new switch?
2005 325i
Chris
1 - 1 of 1 Posts
