I just recieved my 325is from my uncle. I want to know what i should change to keep the car running like it was brand new and not 16 years old.
This is what I got done so far:
NEW cat
New O2 sensor
spark plug wires good
spark plugs good
Suspension good
oil okay
coolant good
What i think i need to replace or tune:
Valve gasket
Valve adjustment
fuel filter
I do have a new valve gasket, but its is bent little but, very little. Is it still useable?
The big issue if it is a 6 cylinder it has a rubber timing belt.
That belt if it breaks will make junk of the engine.
It is normally changed every 50,000 miles or every 5 years.
Make sure it is changed or get someone to do it.
Congratulations and welcome.
Here is a link to BEN, BMW E30 Network, lots of good information on e30s there.
http://www.bmwe30.net/cgi-bin/datacgi/data...report=sections
Later,
hmmm mayby the air filter and :idea2 fuel filter
CHANGE OIL, Check your gaskets. Change Coolant and Clean water. if not you could be where i'm at :) for just driving it. but yeah change that oil if your already iffy with it. Oil change isn't even expensive or hard to do so go for that. Simple *mod would be the Cone Intake. And if u wanna do a big mod. From a fanatic i met at the junkyard. The "Orca" mod
