1 - 18 of 18 Posts
there is another post with this picture, but i was wondering if any of you m3 gurus might have the time to maybe compose or add to this post a list of wat these parts are called, i can number em if you want then all you have to do is explain, or u can number it urselfs up to u, but this list would be a great help to all the m3 owners/builders out there
it should work if it doesnt right click and click show picture...
maybe you should go ahead and number it so that its easier for people to come in here and say all the parts they know, then later we can gather all of the parts together into one big list
Originally posted by SpeedInfusion@Dec 11 2003, 05:11 PM
crap its not working for some reason, help? 70 items
what format is it saved as?..
alright seeing as how no one has posted and i made the pic i will decide the format :p ...don't resist the borg
when posting start with the number followed by the part and its function.
Example:
7. Exhuast manifold. To funnel exhaust gasses from exhaust valves to catalytic converter.
58. Engine short block. Conatins the pistons and the crankshaft.
mass majority of the parts there are pretty self explanatory if you know about cars
76. Alternator. supplies electricity to the car and battery, powered by a belt ran from the crankshaft.
71. Radiator Fan. Pushes air though the radiator to cool off the engine.
6. Oil Sump. Contains and cools the oil before being pumped into the engine.
hard to tell from the picture desmo but it looks as if it is installed on item number 67
right....
1 ignition harness
2 ecu cover
3 ?
4 ecu unit
5 oil pipes
6 sump
7 exhaust manifold
8 shroud ? not sure what for.....
9 crank out put flange
10 clutch pressure plate
11 clutch plate
12 oil di sick tube
13 fly wheel
14 cat's
15 head gasket
16 rocker cover gasket
17 ?
18 out put shaft seal retaining flange
19 starter motor
20 earthing lead for starter motor
21 water pipe
22 spark plug leads
23 engine mounting bracket
24 air box
25 mounting bracket
26 ?
27 ?
28 valve collets
29 exhaust valve springs
30 inlet valve springs
31 exhaust/inlet valves
32 cam followers
33 cam shaft
34 cam shaft
35 cam followers
36 exhaust/inlet valves
37 inlet valve springs
38 exhaust valve springs
39 valve collets
40 ignition loom and leads
41 inlet manifolds
42 ?
43 ?
44 fuel pipe
45 fuel feed rail
46 injector rail
47 alternator pulley
48 power steering pump
49 rocker cover (plastic)
50 cam cover
51 cam wheels cover
52 cylinder head
53 oil pump drive shaft
54 oil pump and filter housing
55 oil pipe
56 sump gasket
57 oil pump
58 cylinder block
59 timming chain housing
60 lead to igniition
61 water pump
62 little end gudgeon pins
63 pistons
64 con rods
65 crank
66 ?
67 timming belt housing and tensioner
68 air conditioning pump mount
69 air conditioning pump
70 crank pully
71 viscious and fan
72 auxcilery tensioner
73 pully
74 ancillery belt
75 pully
76 alternator
77 pulley
woo thats all i can rember.... :lol:
1 - 18 of 18 Posts
