Hello, i am a new member to this forum and looking to buy a 318is and convert it to an M3. I have found a lot of information about converting a 318ti but none on 318is. I know that there are a lot of problems with the 318ti because of the rear. Anyway, has anyone heard of 318is to M3. Do you think there would be any problems after the conversion and do you think I can do it with a friend (My friend has a shop but I will probably be doing most of the work). I probaly can't spend more than 10k on the 318is or i and the conversion. I found a website that sells a 3.0 S50 engine+all the parts requied for the conversion but they did not say anything about converting it to a ti. The price is 7k for the kit so i need to buy a 318is with high milage or a blown engine or something. They just said that it was possible for an E36.
Thanks in advance for any replies.
I am about to buy a car, i need cheap insurance and so a 318is will look better than an M3 on paper. But i still wanna have some fun with my car.
Discussion Starter #2
Sorry i forgot to mention this, is the body of the 318is the same as the M3's meaning size and layout. Are all of the E36 coupes the same?
The front end on a 318i is shorter becuase it is a four banger....I don't think you can put an s50 in there, ask furious...though....for the price you would spend, I bet you could hook up a big turbo in there....
It actually has been done to a 318ti, there is no problem in the front. The engine can fit in the front. With the 318ti though, they had trouble with the suspension and strut bar in the rear cause it is 6 inches shorter than the is.
Dude Asio, I almost next to you. I live in Foster City, next to San Mateo. Do you go to Half Moon Bay High or are u in college?
insurance wont be much cheaper cause you have to insure the $7k you put in for the conversion (well you dont have to, but it would be smart). even if you are ASE certefied, or have some experience working on cars theres a good chance you'll need a mechanic to bail you out of a few tough spots, which wont be cheap and will cause the whole conversion to be put on hold if you spent your last penny on parts. what all is included in the $7k 'kit'? you will also need a full exhaust, and will probably have to put money into the suspension. in the end you wont be saving much by converting a 318 rather than buying a M3 as e36 m3's are getting pretty cheap.
The engine though would have only 46k on it, plus it would be tuned already with euro parts.
Here is the thing that is on the page.
S50USB30 engine - The perfect motor swap for your E36!
3.0 Liter engine complete with wiring harness, DME, transmission, and all ancillaries.
from 10/95 production M3 with 46,XXX miles on the odometer
hardened valve retainers installed at the factory
has been on synthetic oil since new
consumes no oil, ever.
Includes:
Wiring harness
intake tract from the filter through the manifold
DME
Upgrades:
3.5" shielded intake
Euro HFM
24 lb/hr injectors installed in the fuel rail (stock injectors not included)
UUC Motorwerks underdrive pulleys
ZF320 5 speed transmission
exhibits no cold-weather problems or "sticking" behavior
Includes:
320i transmission mounts
UUC Transmission Mount Enforcers
UUC Motorwerks Ultimate Short Shifter with delrin carrier bushings and cartridge bearings
UUC Motorwerks Stage II Lightweight flywheel (8.5lbs) with M5 clutch, less than 5k miles on this setup (stock flywheel included)
Other parts included to facilitate installation:
stock exhaust manifolds
catalytic converters
UUC Motorwerks System.U catback exhaust (stock muffler not available)
M3 differential carrier
M3 3.15 limited slip differential
This engine was dyno tuned at ERT to optimize AFR with the larger injectors. Dyno graphs from this session show more than 230hp at the rear wheels - click here. Since that time, the pulleys have been added, so the actual rear wheel horsepower number is higher than that.
This is a well cared-for, strong motor, with a documented history, dyno graphs, low mileage, and the updated factory retainers. All it needs is a good home.
Complete package - $7500 plus freight
Sweet dude, yea I go to HMB high...how about you?
