My Driver Side, low beam headlight is burnt out, I tried replacing the bulb and nothing, checked fuses appears ok, can anyone tell me what fuse number is the low beam light (since mines in German) or what the problem could be?
1992 316iA
Fyi I fixed the problem by replacing the 7.5 fuses with 10 amps, now it works.
So I installed the Phillips blue low beams.
AHAHHA i know ur problem. the headlamp bulbs you are using must be more wattage than your stock headlight has. Blue ones killed mine too!
p.s. phillips blue r sweet
Millions of them.
i have a 525i and I did the same thing...should I just pop in a 10A fuse in there if it is not already. because i dont want those suckers dying on me in the middle of the night/ nowhere
I dont know just carry a spare 10a in your fuse box, Ive read in other forums, you can put up to 15a,, but thats what ive read..... 10 works fine and im happy now
