Hey i had a quick question
Does any one know what the coolant lines going to the original intake air box (where the filter is at) are for?:conf
I would really appreaciate the help cus its causing my bmw to overheat and i want to know if i can just eliminate it or just plug it up
see here for model of car
:bs:bs
that is ur fuel injection thermostat a very inportant part not to be messed with. but the part that the hoses conect to can be carfully removed and taken apart cleaned o rings replaced may hel not gettin flow wont tell comp temp of air intake car wont run right can gat new 1 for 90 bucks at pelican prts
but i took it off and pluged the lines cus i broke the thermostat part... but the car is running fine... i put an aftermarket intake that didnt have a place to put it so if i did buy the part where would i put it?
also no check engine
yes they are brittle well i have and aftermafket well/ made my own intake and i put a port on it be for masair most aftmrk have 1 and u should replace it help fuel mile and motor from over heating there abot 57 bucks if u look pelican has them2
