1 - 11 of 11 Posts
I was wanting to change my instrament cluster from the 318i top speed of 140mph to another cluster..... one from a 325 or something..... it has a top clock read ot 160 i think....
basically cause i can t get thoese nice electro luminesance faces for mine.... but there are loads for the others....
i wanted to know if it would cause a problem with miss readings or it will correclt y display speed, rev, mpg, blah blah blah.....
cheers
hmm, thats odd. My 318 has the 160 speedo.
I don't believe that will work because your sensors will be calibrated for the older cluster and will throw off your speed and rpms.
cheers
the m3 was the only one to have the speedo at 160
Yeah my 325i also goes to 160
Originally posted by El Presidente@Jan 15 2004, 05:56 PM
sure about that?
thats the first one i have seen :confused
Discussion Starter #9
it is a bit dtrange that mine has the 140mph max.... but it was a change over year 1993/94 318i (8v) 4 cylinder......
i think ill find one at a scrapy and try it for a laugh.... if it works ill let you know.....
If you swap clusters, you'll get a manipulation dot in the odometer area. This little read dot indicates that the mileage/cluster was tampered with. The mileage of the vehicle is stored in another module :p for backup purposes, and if they don't match the manipulation dot will come on.
1 - 11 of 11 Posts
